rickyman
problem with cool drive 4
rickyman    0
i have installed cooldrive 4 inside the pc. when i turn on the pc, it started beping alot. when the cooldrive 4 turn on, i only can read the rpm for cpu and case fan and hd and not temp on it. i did put the sensor on the cpu. oh yeah, sensor on the cpu keep loose . i cannot put the tape on it.
i need to know where to buy strong tape for the sensor. because it always loose.
Guest Mindless Moron
the sensor reads temperatures anywhere, the yellow wire on the fan provides speed detection make sure you have them
Mr. Miyagi    2
Make sure all of your temp probes are connected in. You can use cello-tape to fasten the probes down.
Create an account
Register a new account
Sign in
Sign In Now
