CM Bram
MasterKeys Pro L and S - Mega Thread
Bongripper    0
I have bought the CM Masterkeys Pro S (MX Red) two weeks ago and i'm really satisfied with it.
Last week i tried to play around with the backlights, but even with the online manual, i can't get it to function properly.
For example, how do you have all keys illuminated in white and bind this function to a shortcut? Just a simple switch for day/night use. I don't understand the software at all.
Mihai C    0
Hi,
sorry for newbie question, but I bought a Masterkeys PRO S (RGB) today and I don't have any software in the box (no CD or anything else). Can you tell me where I can download the software (a link) please?
Thanks a lot!
L.E. I found it...
Edited by Mihai C
knud    129
You need to bind them under a profile (P1~P4) key.
Check this tutorial video: https://youtu.be/EVHoc3L2zOo?t=161
  • Upvote 1
XipHiaS    0
Got a problem with my keyboard (Masterkeys Pro L version).
Key's: 5, T, G, V, F5 and P1 stay lit red in a very dim way all the time. They can't be adjusted to zero light/ off.
Already reset the keyboard (unplug FN+RAlt re-plug) and (while plugged in FN+E for 5 sec).
Loaded the latest firmware. Tried resetting with the software. Problem stay's.
Tried enabling different profile.
Looks like those key's red are variating a little bit in brightness all the time random. Loose contact or software error?
Can't remember for sure, but i didn't think i saw these keys in this red lit state before. Because i mostly have a color wave going on which hides the 'defect' a bit, i just recently noticed it.
What to do? Known problem?
Edited by XipHiaS
Bongripper    0
Finally got it to work yesterday. I now have binded the "day profile" to P1 and the "night profile" to P2. Thanks again and sorry for the late feedback.
Edited by Bongripper
knud    129
8 hours ago, Adi S said:
Download a profile that matches with your product. Inside the downloaded folder, there should be an executable file that will trigger/activate the effect.
(You cannot add them to the software or profile at this stage).
Good to hear it :)
XipHiaS    0
After a few days of use my "new" keyboard has the same issues. Now the [Print Screen], [Up] and [Down] arrows and keypad [Del] and keypad [8], [insert] and other [Delete] stay red :( . Think it's time to exchange again.... Maybe look for a different model... Really liked the KB...
