joedap
Master Case 5 Pro stock fans
joedap    0
    I've been trying to find the specs on the stock fans for the Master Case 5 Pro, but the only thing I've found so far is 2x 140mm in front intake and 1x 140mm fan in rear exhaust and all 3 are 1200 rpm.
    I'm going to be installing a Corsair H100i v2 in the top with the fan set for exhaust. Not knowing the specs of the stock fans I'm not sure if the front fans should be replaced with something better so I will be running with positive pressure in my case.
  Any info would be greatly appreciated,
Joe
