Christian Richard
Custom macro delay for CM Havoc
CM Bram    35
Can you be a bit more precise what you want to record? You should be able to set custom macro's including specific ms values..
This video might help:
He means selecting a custom delay value per key press.  This used to be available in the Sentinal Advance II software, but is not present in the CM Havoc software.
For example using an MMO.  We want to time the button presses precisely;
Press 1 Key - 12ms
Release 1 Key - 12ms
Press 2 Key - 2500ms
Release 2 Key - 12ms
Press 3 Key - 1234ms
Release 3 Key - 12ms
We can't manually edit the timing (ms).  This would allow us to precisely control the creation of a macro.  We can record our keypress, but it's not as accurate.  Seems like a simple request.  The macro file already contains these values, but we are unable to edit from the UI or via text editor.
This is a major issue.  If we can not control timing of the macro precisely, what is the point of the macros?
Edited by Matt Crawford
Create an account
Register a new account
Sign in
Sign In Now
