Brian Adams
Cooler Master V8 GTS Controls HELP New to this forum setting
Brian Adams    0
How do I adjust the speed of this fan?  Thank you so much.  I couldn't find this on another forum.  If you know of one, could you direct me there.
Sunday Morning    174
Hi Brian .. Wellcome to CM forum
Iam not prety sure if this is correct answer :(
According CM website V8 GTS specs : Fan Speed = 600 – 1,600 RPM (PWM) ± 10%
PWM fans can have their speed controlled by your motherboard's PWM capabilities and software like SpeedFan.
other Solution : try sent out the ticket .. or try live chat with CM agent probably they can help you
Hope this can help
Edited by Mohd Noh Tanjong
You can plug to the MB and let it control the flow.
While I'm living in a tropical country, I just let the fans run on max speed and using high pressure air to blow the whole casing once every 2 months to remove the dust.
CM Patrick    34
Hello Brian,
If the fan header that the V8GTS is connected to is set to AUTO, then the fans will adjust based on CPU temperature.
You can also adjust the fan RPM by changing the AUTO setting to something else like Full On, Turbo, Normal, Silent, etc.
If your motherboard has a software application then you should be able to use that program to adjust the RPM in windows.
Patrick
CMUSA Support
  • Upvote 1
