Richard Alexander
Cooler Master Seidon 120v Ver.2 Pump Noise
That is nice ...
May i know how you install your seidon ..can share ? ? :)
pump connector ..connect to ?
Fans Connector ..connect to ?
I used my first setup with pump connected to 3-pin PWR_FAN and fan connected to 4-pin CPU_FAN. Pump runs at full speed as it should and the fan is controlled with temperature of CPU.
All is good.
CPU can get down to 22°C and up to 40-55°C depending on the type of load.
Fans are fairly quiet too. Good airflow but no space to dual fan. Just pleased it's all working nicely!
Sunday Morning    179
Thanks for the Sharing ... and Enjoy your Seidon :)
by the way .. why no space for the dual fans ? ?
Well i didnt want to make a new thread so I will post here.
I got a Seidon 120v v2.0 aswell and i have also that annoying noise.
Searched all the forums, tried everything, waited days, but it just wont go away.
So this is what mine sounds like. Is that noise normal? Also keep in mind that compared to my air cooler temps are 5-8C higher on idle.
https://youtu.be/gyIgN230Czw
Edited by Nick Gouzoumas
Sunday Morning    179
Hey man .. sound not bad ... :)
RMa is the best way .. since you have Rock sound in there :)
Edited by Mohd Noh
Sounds a bit like how mine sounded.
I returned the noisy one and got a replacement.
The replacement sounds much, much better. It is quieter and I hardly notice it now.
I'd recommend a replacement and see if the new one is any better.
I see, well thanks guys, most likely I will go for RMA soon, and maybe then sell it. I dont know i got disappointed by the temps.
What were the temps exactly?
Mine will idle around 30c. Obviously, it cant go below room temperature so it will depend on how hot your environment around the PC is, but if the temps are high, I'd say faulty pump
Sunday Morning    179
Agree .. totaly agree ... my seidon under 30-32c idle but i have 6 Jetflo 120mm
As faulty unit .. RMa is the best way
Create an account
Register a new account
Sign in
Sign In Now
