Richard Alexander
Cooler Master Seidon 120v Ver.2 Pump Noise
Hi all,
I've recently purchased and installed a Seidon 120V Ver.2 cooler, however the pump block seems to be making a loud whirring noise. I would guess it is the impeller rotating.
See the following vid:
Motherboard: AsRock H81M-HDS
1x 4-pin CPU_FAN - radiator fan connected here
1x 4-pin CHA_FAN - front case intake fan
1x 3-pin PWR_FAN - pump
I have tried the pump on a molex connection and it makes the same noise.
In BIOS, the pump RPM is roughly 2300.
This is also reflected in the AsRock System Information:
Can anyone advise whether this is normal operation or should I seek a replacement cooler?
Thanks
Mohd Noh    179
Hi Richard
Wellcome to CM forum
try check our previous thread : http://community.coolermaster.com/index.php/topic/15850-seidon-120v-making-bubble-noises/
Here is my current setup
1, http://postimg.org/image/v9tzpgo61/
2, http://postimg.org/image/jlzxuwz15/
My pump speed with performance setup in bios 2.2k idle 30-32c load 40-45c
try change as below
1x 4-pin CPU_FAN - radiator fan connected here ( Change it to Pump connector )
1x 4-pin CHA_FAN - front case intake fan  ( Change it to Fan connector )
Hi Richard
try change as below
Hi, thanks for the response.
This made no difference, unfortunately
Mohd Noh    179
Pls check this thread : http://community.coolermaster.com/index.php/topic/15850-seidon-120v-making-bubble-noises/
so try run your seidon ... atleast 2-3 days and see how .. if the noise still there .. return it to your local store ( RMA )
Edited by Mohd Noh Tanjong
Thanks.
The noises aren't bubbles. I know the pipes make those noises in some systems but not this one.
It's been running for a few days now but there's no improvement.
I've asked for a replacement so shall see how that one sounds.
I shall update this when I have it
Mohd Noh    179
Thanks.
It's been running for a few days now but there's no improvement. ( My Seidon Run 48h ++  Non STOP :( after that all the noise die :) only silent stay a around )
Thanks, I saw this one before.
I had tried those BIOS settings already and the pump made the same noise when it wasn't screwed down either, so it wasn't because it was too tight.
My package has been picked up and will be replaced soon
Update: The replacement Seidon 120v came today
I have installed it and it is much quieter than the previous one, thankfully!
There's a lot of dripping sounds coming from inside but I'm guessing that will ease after a few days of use.
Mohd Noh    179
That is nice ...
May i know how you install your seidon ..can share ? ? :)
pump connector ..connect to ?
Fans Connector ..connect to ?
Create an account
Register a new account
Sign in
Sign In Now
