Jacob Roberts
CM Storm Trooper front panel/LED weirdness
Hi, I recently purchased this case (CM Storm Trooper) and am very happy with it apart from this little problem. I'm sure I've connected everything up correctly, however, the LED lights in the front fans are always flashing except when on full fan speed. The LED button only toggles between a more powerful flashing and a slightly dimmer flashing, it does not switch them on or off.
As well as this, when I play my electric guitar near my PC (which always picks up electric noise regardless, I know) I can hear this as a rhythmic ticking exactly in time with the flash, which leads me to believe it could be a power issue with the panel. It goes away when fans are set to full speed.
Any suggestions or is it just a faulty panel?
Thanks
