Keir Bourne
Mizar not detected
Keir Bourne    0
Hello
2 months ago I bought CM Mizar mouse. It set up easily but occasionally would disconnect and only reconnect when I fiddled with the USB port.
However now it is not working at all. I have tried putting the USB cable in every single port, doesn't work. It did turn on at one point, with the scrollwheel lit up but not the logo and I couldn't do anything. Although it had power, buttons did not work and couldn't move the mouse.
Any ideas what to do? I like the mouse don't really want to RMA, but if it has dodgy cable then maybe there is no other option.
knud    129
Just to make sure: the mouse works fine on another computer or laptop?
If you get the same result, then you would have to RMA it I'm afraid.
