robear7nt
Stock Stacker Fans
robear7nt    0
Is it worth replacing the 3 "stock" fans that come with the Stacker to fans that can be plugged into the mobo's fan control ports? I have a Intel D925XCV mobo. Am I correct that the stock fans can only be powered by the PSU w/o any variable powering?
I'm not into modding myself, but you all have some pretty AWESOME looking mods!
Guest Mindless Moron
only repalce them A) if u want led or uv fans or B) higher output fans
TronX    0
Stock is normally good enough. The only time I've seen people replace them is if they are going after a color theme or needing less noise.
NeOn    0
I plan to replace my 120mm's with silenX.
I already have all the 80mm spaces in the case decked out with 80mm silenX
the silenx fans are absolutly terrible, they lie about hte noise and aireflow, there is actually no point in them air flow is barely increased, cm's silent 120's get on my nerves as you can hear they're motor which makes a sort of god my computer hasnt been on in so long i cant remember aaaaaaaaaaaaahhhhhhhhhhh cm's silent 80s are good tho slight high pitched whoosing noise
