WestRJ
CM Scout 2 Front Panel Faulty
WestRJ    0
Hi
I have recently purchased a CoolerMaster Storm Scout 2 chassis. I experienced soft voice output on the front panel speaker. After checking the cable, motherboard connection etc....
I found shoddy soldering on the front panel (see pictures). The chassis serial number is SGC2100KWN11151400070 (could not register on website). Will also contact local dealer but cannot wait 2-4 weeks for replacement.
Regards
René
Pclinde    197
Hi René,
Since you recently bought it, please try to solve this with your local dealer.
Cheers,
Pim
cheers? you just told a customer to buzz off its not your problem ? its a brand new case covered by manufactures warranty of defective shoddy manufacturing and your pawning it off to the retailer ?
REALLY ??  this happened to me the same day i received my scout 5 years or so ago when i had a similar issue that to this day has not been addressed. I can tell you right now the retailer will not back the product repair or replacement because coolermaster will most likely not reimburse them as well and they know it
