Chowchilla
Cooler Master Seidon 120V V2 loud humming/ticking noise.
Chowchilla    0
Greetings.
I've had this AIO installed for 2 days now and no matter what i dont i cant get rid of this loud humming/ticking noise.
the PUMP is running at 2500RPM in the bios, its not limited in any way.
http://www.youtube.com/watch?v=_-rmfEix1KE&feature=youtu.be
the video doesnt do it justice as it sounds that loud when im at my desk and the case is off by the right of me.
ive tried re-seating the pump, changing fan headers and using a 3 pin to molex adapter.
the only way i can get it to be silent is reducing the RPM to 1000rpm.. but at that speed its idling at 40 degrees.
any suggestions?
Thankyou.
Sunday Morning    178
Hi and Good Morning
what kind spec you using for that seidon ?
my pump running at 2.4k with performance setup
with i5 4690k and z97xgaming 5 my idle 30-32c load at 43-45c
Sunday Morning    178
Just finish watch you vid .
CPU x 1 / System x 4 FAN connectors << try connect the Cpu Fan Header to your pump connect
the sound not bad ... probably that is air burbble
long time ago iam facing this issue .. i have ON my seidon around 48h non stop :) in the end my music in there .. gone :)
Chowchilla    0
Hi and Good Morning
Hi. ive tried every fan connector, 3 of them allow for variable RPM, 2  have no control and fun at full whack all the time. its defiently not a power issue as ive hooked the pump to the PSU and it still makes the noise.
my specs are :
MSI Z77A-G45.
Intel Core i5-3570K
MSI GTX 970
BEquiet 630w PSU.
the noise is odd, its more of a electrical buzz than anything. its been on for afew days now and its not stopped.
Sunday Morning    178
HI
did you try setup at bios ?
World's 1st UEFI and software graphical user interface
MSI Click BIOS II provides a consistent user interface both in the UEFI BIOS and in Windows, it provides the most convenient way for users to control system settings and supports touchscreen control.
Benefits
- Graphical User Interface, with touchscreen support
- Simply click or touch and move to change settings
- Full system control, including overclocking, security and information
try check you bios and see how ?
before i jump to z97x gaming 5 .. i have z68 .. and have to set my bios to default .. if not i also can hear some noise ...if i set more than that
and stay connect your pump radiator at Cpu fan Header ..
hope this can help you
Create an account
Register a new account
Sign in
Sign In Now
