Iraklis
Razor's Edge
Iraklis    18
Today i found some time to work with the 2nd LED bracket. Now its time to start working with the actual leds and acrylic.
Cheers
Iraklis
Iraklis    18
Are we ready for some LED action ??
This is an old RGBW led tape i found, its super bright and it works like a charm with my RGB controller.
Cheers
Iraklis
  • Upvote 1
Iraklis    18
Hello everyone.
I just came back from my vacations and found some time to work with the led plexi, its still incomplete but you now you can have an idea how its going to look.
Cheers
Iraklis
  • Upvote 1
Iraklis    18
Today i finished one of the led panel. Unfortunately i messed up something and the led controller doesnt work. Ill have to sort it out later, but you can get an idea how its going to look.
Cheers
Iraklis
  • Upvote 1
Iraklis    18
Since i wansnt able to sort the things out with the LED controller, i order a new one and the mean time i decided to work with something else. I decided to change the brown anti vibration pads with the white ones. Tomorrow ill sleeve the cables and work with some custom stickers.
Cheers
Iraklis
Iraklis    18
Today i finished sleeving the fan cables. I like the result of watering tubing a lot and i think ill adopt it in my future builds.
Cheers
Iraklis
Iraklis    18
Today i worked with the led controller cover. Unfortunately i wasnt able to fix the old controller and i bought a new one.
Tommorow i hope that ill be able to complete the cover.
Cheers
Iraklis
Iraklis    18
After many tries i completed the most parts of the LED Controller. The only piece i miss is the top lid and it is ready. I also decided that ill have the controller outside of the case.
Cheers
iraklis Edited by Iraklis
Iraklis    18
Hello everyone.
Today i finished the LED controller, if everything goes by the plan tommorow ill fire it up for a test drive. I also started the painting of the case
Cheers
Iraklis
  • Upvote 1
