Trajans 0 Posted January 23, 2016 I've got an old Cosmos S (RC 1100) tower. I'm in the computer upgrade process, and wondering if the Nepton 240m is compatible with the case. Thanks. Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 23, 2016 Hi Yes .... The Cosmos S is Support up to 120mm x 3 radiator on the top . no issue for Nepton 240m Below is some picture for your reference Hope this can help Share this post Link to post Share on other sites
Jerome Zepol 0 Posted January 26, 2016 how about for HAF 912? whats better fit? Share this post Link to post Share on other sites
Frank Gillette 0 Posted January 26, 2016 I have read elsewhere that the Nepton 240m is not compatible with the HAF 912 case. The Nepton 120xl should fit in the HAF 912 though. On a different subject, does the Nepton 240m fit in the HAF XB EVO? I'm getting the HAF XB EVO, an upgrade from my HAF 912. Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 26, 2016 I have read elsewhere that the Nepton 240m is not compatible with the HAF 912 case. The Nepton 120xl should fit in the HAF 912 though. On a different subject, does the Nepton 240m fit in the HAF XB EVO? I'm getting the HAF XB EVO, an upgrade from my HAF 912. Hi No issue .. Front: 240mm radiator x 1 (optional) (Compatible with the Nepton 280L) and also check this : https://pcpartpicker.com/b/hjM8TW Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 26, 2016 how about for HAF 912? whats better fit? Hi pls check this : http://www.overclock.net/t/1315321/corsair-h100-and-the-haf-912 Share this post Link to post Share on other sites
