Manny Macho
Coolermaster Pro 5 motherboard sizes
Sunday Morning    174
Hi
You can check this : http://community.coolermaster.com/index.php/topic/14584-mastercase-5-ceb-support/
EEB is large motherboard and official Master Pro 5 only support up to ATX but some user can put in the EATX motherboard into the chassis but you will have a bit less room for cable management through the openings
** Not recommend that EEB type motherbaord for your Master Pro 5 Case.
Hope this can help you :)
