Sunday Morning 177 Posted January 1, 2016 Hi i found some .. maybe this vid can help you : Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 1, 2016 and this : http://community.coolermaster.com/index.php/topic/12563-nepton-280l-rattling-noise-from-pump/?p=117106 Quote Share this post Link to post Share on other sites
Martin 0 Posted January 1, 2016 i dont know for asus board i have seidon 120v only with gigabyte board and have 4 type 1 full speed 2 standard 3 perfromance 4 quiet already test the all type .. my best performance is no3 no noise and no higher temp asus bios settings, 1.standard 2.silent 3.turbo 4.fullspeed 5.manual and its full speed selected PWN, also have some DC mode and when i select DC pump goes down to 2200-2300rpm and i don't hear anything like rattling its silent like that and temp was good too but it everyone says if it doesn't run at full speed it can damage the pump so i run it at full speed. Quote Share this post Link to post Share on other sites
Martin 0 Posted January 1, 2016 and this : http://community.coolermaster.com/index.php/topic/12563-nepton-280l-rattling-noise-from-pump/?p=117106 Connected pump into system fan and run it at full speed no change, also unscrew abit and again no change, pump is only silent when case is upside down and when i put it upside down it makes swoosh sound for about 10-15min and then completly silent and after back to normal position its rattling again. i will rma it anyway, its my second nepton 240m with same problem definetly poor quality control, in future i will think twice on buying coolermaster product. Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 1, 2016 asus bios settings, 1.standard 2.silent 3.turbo 4.fullspeed 5.manual and its full speed selected PWN, also have some DC mode and when i select DC pump goes down to 2200-2300rpm and i don't hear anything like rattling its silent like that and temp was good too but it everyone says if it doesn't run at full speed it can damage the pump so i run it at full speed. i copy paste from our previous admin : please make sure the pump is running between 1300 to 1400 RPM. If it falls below 1300, it can cause damage to the pump and cause rattling. Quote Share this post Link to post Share on other sites
Martin 0 Posted January 1, 2016 i copy paste from our previous admin : please make sure the pump is running between 1300 to 1400 RPM. If it falls below 1300, it can cause damage to the pump and cause rattling. Pump is running at full speed from day 1 so it never runned that low, lowest was 2200rpm and that was only in bios, after that i set it to full speed again. Quote Share this post Link to post Share on other sites
Sunday Morning 177 Posted January 1, 2016 Pump is running at full speed from day 1 so it never runned that low, lowest was 2200rpm and that was only in bios, after that i set it to full speed agai well maybe some one can help you ... and i think 2.2k 2.3k rpm is prrety good enough .. should be fine Quote Share this post Link to post Share on other sites
Martin 0 Posted January 1, 2016 at full speed pump is running with 2900-2950rpm so i am afraid to lower its speed.. someone help should i lower speed to 2300rpm or RMA this cooler again ? Quote Share this post Link to post Share on other sites
luciferuru 0 Posted January 2, 2016 How do you lower it ? If i connect the pump on the cpu_fan or opt, Fan xpert 2 tell me i cant change the speed of my pump. If i put in turbo mode, or other mode, the pump still run at 2700 rpm. I am on an Asus motherboard Quote Share this post Link to post Share on other sites
Martin 0 Posted January 2, 2016 How do you lower it ? If i connect the pump on the cpu_fan or opt, Fan xpert 2 tell me i cant change the speed of my pump. If i put in turbo mode, or other mode, the pump still run at 2700 rpm. I am on an Asus motherboard in bios you got PWN mode and DC mode when you select DC mode pump is going down to 2200-2300rpm and fans are going up to 1500rpm temp stays same but even with those rpm i can hear rattling when i go close to the case so definetly RMA again.. really disappointed from this product.. big fail because this is my second and now i need to try 3rd one and if that one is fail too than that will be my last CM product. Quote Share this post Link to post Share on other sites
