Martin
Cooler Master Nepton 240m pump rattle
Martin    0
This is my first post so hello to all and happy new year. As the title says i got a problem with my brand new cooler master nepton 240 and the problem is that the pump is rattling constantly and its set full speed in bios. This is my second CM Nepton 240m, i also got the same problem with the first one and i got replecament under warranty but the second have same problem, cooler is working approx 15h nonstop and rattling is still there so i want to know what should i do, should get another replecament or request full refund from the seller because i got 2 faulty products both with same peoblem.
Martin    0
Hi mohd noh,
my system specs:
i7 4790K @ stock but great temps with the nepton 240m,
Asus Maximus VII Hero
Kingston HyperX Beast 2400MHZ 2x8GB
Gigabyte GTX970 G1 Gaming
Gigabyte ODIN 700W PSU
Samsung 840EVO 250GB SSD
1TB HDD WD EZEX Blue
Case Cooler Master HAF 932 Advanced with nepton mounted on the top.
Sunday Morning    174
Hi mohd noh,
my system specs:
Hmm can you explain regarding the installation ... example pump and fans connector
Tips. try dont over tight the screw
try check might can help you : http://community.coolermaster.com/index.php/topic/11937-help-i-have-a-problem/
Martin    0
Its pull configuration on fans.. approx 30hours without shuting down my pc and pump still rattles i think this one is faulty pump too or to much air in the system.. i am going to RMA this one too and see what happens with 3rd if not then i am getting refund.
Sunday Morning    174
Hmm before you going RMA my suggestion try recheck your installation and try on atleast 24h and see how
and try research our previous topic : http://community.coolermaster.com/index.php/topic/10787-official-nepton-owners-club/page-12
and this : http://community.coolermaster.com/index.php/topic/12541-bruit-pompe-neptone-240-m/
Martin    0
I put my case upside down and pump is making random swoosh sounds and it isn't rattling and buzzing now only swooshing at random, should i leave it like this for 1 day or shouild i put it in normal position ?
Sunday Morning    174
you can try in normal position and see how ...
but before that just make sure you connector is correct and try loose alittle bit the screw
Martin    0
Pump is connected to CPU_OPT and its on full speed, and fans are on CPU_FAN and its speeding up depending on temperature. I'll try to loose screws and see what happens.
Sunday Morning    174
i dont know for asus board :(
i have seidon 120v only with gigabyte board and have 4 type
1 full speed
2 standard
3 perfromance
4 quiet
already test the all type .. my best performance is no3  no noise and no higher temp :)
