Jacob Hirsch
CMS-693-KKN1 180 mm side fan
Hello to all members,
I am a new member, bought a CMS-693-KKN1 case.
The specification lists the possibility to install a 180 mm side fan.
I bought a Silverstone SST-FM181 180mm variable speed silent fan but the installation holes on the side panel do not match the fan holes.
Could anybody specify a make /model of a 180 mm fan that will match ?
Thanks
JacobH
Hi Mohd Noh,
Thanks fo your reply.
I will take some pictures and attach them, but it will take some time.
The problem with your suggestion is that there are no holes at all for a 200mm fan.
There are 2 sets of holes for 2 120mm side by side fans and 1 set of holes with 155mm spacing.
The 180mm fan has 1 165mm spacing (I measured the one I bought).
I would assume that the 200mm fan would require a 185mm spacing for the holes.
So unless I get some suggestions I will have to use just 120mm fans.
Thanks
Jacob
Sunday Morning    177
Hello again Mohd Noh,
I plan to do just that.
Attached please find a picture and the spec of my PC.
Thanks again
Jacob
Hi Jacob
tq for the picture ...  :)
but i love to see the fan 180mm and the side panel ... as you mention ( the hole not match )
