Stephen Pelletier
HAF X and Nepton 240M Configuration Questions
Greetings,
I purchased a HAF X and want to install a Nepton 240M.  Do I need to remove the 200x30mm fan from the top, or do I install the optional 200x30mm fan for a push/pull configuration.
In addition, can the Nepton 240M be mounted with the hoses to the left (looking at the MB in the HAF X)?  The pictures I've seen shows the hoses mounted to the right.
Thank you,
Stephen
Sunday Morning    174
Hi
i check at google and found some poeple mount the hoses on the left
But you can try right and left side .. which one is better for you and your performance
Regarding the installation Nepton 240m you have take off the 200m from the TOP
