Connor Brady
High CPU temps + electronic buzz noise periodically
I've recently purchased a CoolerMaster Seidon 120v v2. The fitting went fine, however I've noticed when booting today the CPU temp shoots straight up and periodically, there's a buzzing noise.
I can hear the pump working.
There's contact on the CPU
I've tried using different motherboard 3 pin supplies
Any suggestions?
Sunday Morning    179
Hi
what kind specs you using ?
My suggestion try set default your bios but before that try unplug your pump from surface procs
with z97x Gaming 5 and intel i5 4690k  i didnt hear any noise (Bios set to Default)
fyi 3 pin or 4 pin is no issue
i just my finger to tighten up the screw
Hope this can help
Hi, thanks for getting back to me do quickly.
Specs:
MSI A8XM-E35
AMD A10 7850K
8GB HyperX 1866mhz
Cooler master seidon 120v
We've ran the cooler before we even put a cpu in and it made the same noise. I've tried switching where I plug the 3 pin connectors in to no avail
Sunday Morning    179
Specs:
MSI A8XM-E35
AMD A10 7850K
8GB HyperX 1866mhz
did you try check at bios ?
according what specs you have
- 1 x 4-pin CPU fan connector
- 1 x 4-pin system fan connector
- 1 x 3-pin system fan connector
and try check this :
  • What case are you using?
  • Where is the radiator installed?
  • What is your ambient temperature?
  • Is your CPU overclocked?
  • Which tool do you use to readout the temperature?
  • Does the radiator itself feel hot?
  • Possible to post a few pictures of your build?
if you still got same problem ... probably your seidon have problem ( Faulty / Defective unit )
Create an account
Register a new account
Sign in
Sign In Now
