Akuma 豪鬼
Mouse double clicking on single click
- H​I, I have mouse CM Storm Mizar laser - SGM-4006-KLLW1, 3 mouth, every time when I press one click he click double click, I check antivirus and anti-malware, nothing. So I check on windows settings and nothing, check on mouse driver and nothing. When I don't use mouse, he move alone sometimes (not always). So can somebody help me with this? :)
world    84
Do the same problems occur when you plug the mouse into another computer?
Usually if a single click registers as a double click, there is a defect with the switch. If you are within warranty period, I would recommend contacting support to get an RMA.
For the mouse moving around, what kind of movement is it?
Zenith    5
Either RMA the mouse, replace the switch, or set click delay higher. Your mouse is most likely defective based on your observations so the best course of action would to just RMA it.
