egidijus
-5V problem on abit NF7 for RS-350amsp
egidijus    0
dear Gentelmen,
pls help me.
I have installed new RS-350amsp for Abit NF7 but ABIT EQ program gives me siren and says that there is no -5V from this PSU.
Can I REALY use this PSU for NF7 mob?
If I can use it what Imust change in my BIOS as Coolermaster writes this in the manual.
Please help with this.
respect
Ron    1
Hello egidijus,
Im not at the office at the moment so I cannot look up the spec for the RS-350. But it is possible that it has no -5V.
I know for sure the RS-450 has none...
The reason why is that -5V is not required for a PSU.
Just google for PSU Formfactor to read more about that.
The new formfactor 2.1 is a Intel standard that has the -5V replaced with COM
(Dont ask me what it means...Im not a PSU specialist :wink: )
Ron    1
Say Karma Ghost...
Could you send me the question privat so I remeber this tomorow :wink:
Then I will check for you.
Karma Ghost    0
Sure no problem. I talked to Bryant about it for a bit, but I'm really not all that worried. I trust that the supply won't die on me. Even if it does, I trust in CM's staff to help replace it or something.
Thanks Ron.
Ron,
You are correct that our PSU do not have the -5V line as the new ATX 2.1 requirement does not need it. The user can just check on his MB and see if he can disable the requirement of -5V then it will be fine. DIfferent MB varies so be sure to check with the vendor before doing anything.
