BVDSDesign
RAMPAGE V EXTREME OC Panel stays loose
BVDSDesign    0
Hi,
Almost finished with assembling the master case 5. But when I put in my OC panel in the optical bay area, it seems to be staying loose.
The anchoring doesn't seem to fix it in place when moving the slider. Anyone got the same problem or a solution to this?
Thanks
Bouli    7
If you follow the link mohd noh so kindly provided you see i too had that problem.
For now i fixed it by attaching it to a DVD drive.
Check link for more info.
  • Upvote 1
