bagziters
An Aluminium Case, in the Design from CM 690 III or MasterCase 5 Pro
bagziters    6
Hello CM Forum,
I own 2 pieces of  ATCS 201 Aluminium Cases. I have these Cases since 2001. Each Case cost at this time 300 Euro ($).
But the Case is to small for the present VGA-Card Generation an have only 80mm FANs. It is often noisy.
An acoustic insulation is installed, but the FANs are to loudest Parts. 3x Silent Wings 2 at 1000rpm.
I wish me a new Aluminium Case, with a clear design of the ATCS 201 (no one piece of plastic!!! 5kg Alu).
  • Inside of the Case, the practically Design from CM 690 III or better the MasterCase 5 Pro.
  • Ideal has the Case an Hot-Swap Plate for easy mount and connect HDD / SDD.
  • The best one i know with this feature, is the Lian Li PC-Q26
  • The Case dimensions can be copy from CM690 or Masterpiece.
  • But the Case should weight lesser then the SECC steel Case.
  • The Weight should be lower than 10kg in pure Aluminium (empty Case).
I hope that Cooler Master build a new Case that can continue the fame and glory times of the ATCs-Series  with clear liniear elements, not round, and without plastic-parts!
Please CoolerMaster, create a new ALU case (ATCs)!
Sorry my bad Englisch sentences. My Englisch is a little bit rusty.
  • Upvote 1
Mohd Noh    179
Hi Bagziters,
You can post at our product suggestion
bagziters    6
Hello CM Forum,
i bought the MasterCase 5 Maker at last Year (January 2016)
  • The Features are great, but it weight to much for yearly LAN-Partys.
Please CoolerMaster, create the MasterCase only with aluminium. I will buy it.
Or Can you give me the CAD Files for the MasterCase 5, and i create the Parts in ALU for my self.
Create an account
Register a new account
Sign in
Sign In Now
