Rasmus
MasterCase Pro 5 back side panel wobble/rattle.
Rasmus    0
Picked up my MasterCase Pro 5 today and noticed pretty fast that the back side panel, even when secured with the thumb screws doesnt seem to fit right, if you push on it it wobbles and rattles, kinda concerned that it would rattle when i transfer my hardware and fans to it.
Is this a fault with my case or just how it is? Made a small clip showing what i mean:
https://youtu.be/pQTHG5eT9bs
