evin_evin
Nepton 240m Pump RPM
dwilko    5
Hello as far as I know going off the ai suite fan rpm charts etc the pump does sit about that constantly , your pump should stay at normal speed constantly and the bit that does the actual amount of cooling is the fans with the airfflow throught the rad , aslong as the speed doesnt increase decrease a lot or make odd noises should be spot on
  • Upvote 1
evin_evin    0
Thanks Daniel for the resply.
yes it is constantly at 2733rpm.. i think it is fine. Thanks again. (=
dwilko    5
Just had a double check on mine its different some days to others but it is about 2500-2600rpm yours is a bit higher than mine be nice to see what others have got
