Pclinde
CM Storm Xornet II - Claw Style!
Pclinde    197
Hello to everyone,
I've created a subforum for Xornet II s/w and f/w testers. You will find it under: gaming > CM Storm Mice > Xornet II (located at the top of the page). It's only visible for Xornet II testers. Open for discussion now!
Cheers,
Pim
  • Upvote 1
m0uz    2
I'm probably blind but i don't see it. :confused2:
But not much to report anyway, the new fw seem to have fixed all issues.
So, the dropped polls and clown cursor lift-off bug in the software is fixed?
Edit: Also, Pim, you may have accidentally added me to the subforum. I'm not a beta tester, I never agreed to the terms :thumbup:
Edited by m0uz
  • Upvote 1
Pclinde    197
Oops my bad. :) Thanks for being honest. :)
Toni222    1
Not sure i can answer with the NDA, but the polling rate is not something i tested (how do you test this ?), for lift off see #72  :wink:
This is the issues i had with the previous firmware (software and firmware combined) > http://community.coolermaster.com/index.php/topic/14582-cm-xornet-2-software-problem/
Pclinde    197
I still cannot see the forum :happy8:
Did not grant you access. Now you do! :D
  • Upvote 1
