Pattmyn
120mm Rifle Bearing?
Pattmyn    0
A thought just crossed my mind...I have one of the CM Neon LED 80mm fans thats a rifle bearing fan and I love it, very quiet for the preformance. I was wondering if they ever tried a rifle bearing with a 120mm fan? That would be a great idea if they did. :)
Mr. Miyagi    2
I think that would be a great idea. Maybe create a performance version of the 120 so you can recieve higher CFM with the same DBa.
Pattmyn    0
Yeah, that was exactly my thinking. I did a review of the rifle bearing fan (along with some CM roudned cables) and was astounded with the preformance power with the low dba.
Hybrid-Mods    0
I know they make 120mm fans, but i don't know why with sleeve bearings.. I think i remeber being told that rifle bearings are in between sleeve and ball bearing, in quiet terms. but the 80mm fan i have from CM with the rifle bearings is pretty quiet
Pattmyn    0
Yah I have one too, best part is its comparing to a Vantec Stealth in silence but stats of a standard fan.
Mr. Miyagi    2
Yeah, I think they're great! I have 3 80mm myself. :wink:
Pattmyn    0
I would have to look into it but I think my next stealth rig is going to have the 80mm's in it...or I go all 120mm fans.
Create an account
Register a new account
Sign in
Sign In Now
