boddole
Question on CM Storm Software LED Settings
boddole    1
Hello everyone, I noticed that when using the "Default Profile" the led colors of the mouse change with each DPI setting change (Off, Red, Green, Blue). However when setting up my own custom profiles, I cannot duplicate this effect (I seem to only get 1 led color setting that applies to all DPI levels), so I was wondering if this is even possible or if I'm just using the software incorrectly.
Any ideas are appreciated thank you for reading.
-I'm using the Recon with the most up to date software.
Pclinde    197
Hi boddole,
You're limited to one LED color for custom profiles. You can set different LED colors for LED 1/2 & 3.
Cheers, Pim
boddole    1
Hi boddole,
Cheers, Pim
Ok, thanks for the clarification.
