Isaac
Pro 5
Isaac    0
Hey guys I was getting a pro 5 and I was wondering if I can put two 970s in a pro 5 with still having clearance in the case
You should list your exact model o 970, they make many different ones.
I see no reason it wouldn't work.
I have an AMD Radeon R9 390 that is very long and it clears no problem.
Worst case is the front hard drives cage may be in the way, but they are movable (removable).
There is no room past the seventh card slot, so you may not be able to use the bottom (7th) slot if it has a 2-slot cooler.
Isaac    0
i'm not worried about if the length of the graphics card will fit i'm more worried about the gap between the 2nd graphics card and the basement divisor and if there's gonna be enough space between it without overheating my card by a lot,
https://youtu.be/m1VQvEbDrBw
if you look at this video you can see that the second graphics card in there build is really close to the basement divisor and im a little bit worried on how close it actually is to it and that it might over heat my card
CM Patrick    34
Hello Isaac,
Yes there is plenty of room for the second card. I am running two R9 290X 8gb in my pro with out any issues.
You will be just fine with your two 970's :)
Patrick
CMUSA Support
Sunday Morning    177
Hello Isaac,
Patrick
CMUSA Support
Hello Patrick ,
can you share you system .. i wanna see .. can ? :P
CM Patrick    34
Hello Patrick ,
Im actually building a new one and its not finished yet but I will share once its done :)
Sunday Morning    177
Nice ..... oh ya if the goods and no longer in use .. you can throw to me ...  :P
Sunday Morning    177
5 hours ago, Amirali Sa said:
can i put a 3.5 inch hdd and an asus strix gtx 1060 in the case?
Welcome to CM forum
10.7 " x 5.2 " x 1.6 " Inch
27.17 x 13.2 x4.06 Centimeter ( Asus GTX 770OC )
11.73 " x 5.28 " x 1.57 " Inch
29.8 x 13.4 x4 Centimeter ( ROG STRIX-GTX1060-O6G-GAMING )
And below some picture for your reference .
Hope this can help
