berntllye 0 Posted November 3, 2015 So heres there issue I am having. I am using the HAF XB EVO for the case for a Video Recording server I am building and and running into an issue where the XDOCK will only read 1of the 2 4tb WD HDD's that are connected. the bios is up to date and the hdds are readable being plugged directly into the sata cables but not while using the XDOCK. I have been trying to get in touch with customer service for the last two hours with no luck. Does the XDOCK have a maximum supported HDD size or a QVL of what HDD's do work with it? Does anyone have a phone number that dosnt send you to voicemail afer telling you that there is one person infront of you twice? Quote Share this post Link to post Share on other sites
knud 129 Posted November 6, 2015 If you swap the hard drives, still only 1 works? (The same xdock?) Also try different data cables & switch them around There is no maximum supported size of HDD for Xdock Where are you located? Quote Share this post Link to post Share on other sites
david rogers 0 Posted September 28 I am having the same issue. Only top dock works. Quote Share this post Link to post Share on other sites
