swooty
Xornet II in NA?
knud    129
I am located in Romania and I can't fint it here.
I could order it from other european countries but still can't find it...
In the beginning of December it will be available through PC Garrage
swooty    0
( The Xornet II has been listed at Amazon USA already and expect to arrive and be able to ship out soon )
Any chance you know the date amazon should have it in stock? I ordered one on the 8th :)
lapayo    1
I had another OCN user who owns the mouse test it against a 500hz WMO using Bloody's (A4Tech) mouse shooting program which can be downloaded here: https://www.dropbox.com/s/7jrr652uivmog35/Mouse%20Shooting%20Speed%20Test%20V1.6.exe?dl=0
These are the results: http://www.overclock.net/content/type/61/id/2623218/width/350/height/700/flags/LL
A=Xornet 2 (with software set to lowest button latency)
B=WMO@500hz
The WMO@500hz is slower than the original Xornet /w v55 firmware by 11-12ms.
This means the Xornet 2 is slower than Xornet 1 (FW55) by 7-8ms.
I just tested with this tool using my old xornet 1 with my new xornet 2 with Firmware 1.02
I dont know if my old xornet1 is misconfigured, but I get better results with my xornet 2.
http://imgur.com/XZkNi0W
(A is Xornet 2, B Xornet 1)
Zenith    5
You're either confusing which mice are which or you're using the wrong firmware. Either they fixed the Xornet 2 with their new firmware (in which case kudos you CM!) or you're using a Xornet 1 with the laggy firmware (only Xornet 1 v55 firmware has almost no latency)
lapayo    1
Dont know about v55, only know about v7* firmware versions.
According to the firmware reader its running on v75.
Where can I get v55? Then I will test the mices again.
Zenith    5
If both mice give the same result with no clear winner or if Xornet 2 is faster than the click latency is most likely minimal.
