3klikguy
CM Storm Mizar double-triple click when lowering button response time
3klikguy    0
As title says, when lowering the button response time lower than the 8ms default I experience reproducible double or triple clicks (at least on left click) on about 15-20% of presses. 8ms works just fine.
No spills, mouse is one and a half week old.
Tried both firmware versions available.
Thanks.
3klikguy    0
Hi there,
To clarify: this does not happen on other button response time settings?
Regards,
Bram
Doesn't seem to happen on the default 8ms, if I lower to the min or near there it misclicks.
Piru Sama    0
I have the same problem, I just bought a Mizar three days ago (february 10th) from a distributor in my country (Peru) and yesterday the mouse started to make double clicks. I have just set button response time to 8m but it doesn't seem to work.
Edited by Piru Sama
Pclinde    197
Can you test this with another computer or laptop? The button / switch might be faulty. + double check your Windows mouse settings. ;)
Piru Sama    0
Dear Pim van der Linde, thanks for your response. I tested the mouse on different computers (all using windows 10 by the way, I don't know if that has something to do) and the results were the same. But I can tell you I changed the button response time to 32ms and everything seems to work fine now.
When the response time is set to 2ms the double click trouble appears almost 30% of the time I press the left button, when set to 8m the trouble remains but not that often.
I will keep testing the mouse.
woll3    0
It works as intended because you reduce the debounce time, if the debounce time is too low then you get double/triple clicks because the switch is still bouncing and therefore signaling 01010101010101.
Pclinde    197
Thanks for sharing your experience! Haven't seen this problem before. :s
