Bick Benedict
Hyper Evo 212 Question (using with an LGA 1151)
For an 1151 motherboard (I have an Asus Z170 - A), which slot on the mounting plate I use?  The outer, middle, or inner slot?
There is no reference to the 1151 in my manual, but I know it's compatible since there is a sticker on the box that says "1151 Support." Basically I just need to know if I use the inner, outer, or middle slot to screw in the plate. Thanks for any help you can provide.
You need to use the middle slot. (It follows the same installation method of Socket 1156/1155)
http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
Thank you very much. Now that I have you here, can I also ask which screws you use to screw into the mounting plate? Do you use the short ones or the ones that are longer and more narrow?
