Derek Hawkins
Nepton 240M in N200 case
Currently have a Seidon 240M with radiator front mounted in a Cooler Master N200 case and would like to replace with Nepton 240M. Will the Nepton 240M radiator fit in the same location? Radiator dimensions seem slightly different.
knud    125
Yes, it will fit if you install it in the same location.
Thanks! Finally figured as much but got an H100i GTX instead. The N200 is truly a small versatile case, perfect for mATX boards. Discovered that there's provision (undocumented AFAIK) for a single 3.5" HDD installation lying flat at the bottom of the case where the cage would normally go. Won't restrict lower radiator fan airflow like the cage does. SSD can mount beneath radiator behind motherboard as documented.
Create an account
Register a new account
Sign in
Sign In Now
