Gurkirat Singh
About Cooler Master P80
Hi currently I am using AMD Phenom II X4 960T processor and I'm thinking of buying this Cooler Master P80 CPU Cooler.
I just want to know, can it keep cool my Phenom processor [base frequency = 3.0ghz turbo frequency = 3.0ghz and Max.TDP - 108 W { Measured by CPU-Z } ].
By cool I mean at adequate temps. Like 40-50 °C or better than that.
Hope I have given all the information needed. Please reply if you know answers to it.
Thanks.
knud    129
Not sure about your budget and size limitation, but a Hyper TX3 or T4 will fit better with your temperature requirements.
You didn't answer my question I said if P80 is compatible with my processor. I don't want to over clock or something, should it will keep it at adequate temps like 40-50°C or how much acc. To you.
knud    129
The cooler itself will fit/work. But i´m really not sure if you can reach those temps.
