Raeven
Cable lengths...
Raeven    0
So I have purchased and use CM products in builds... but I just have one gripe.
Cables on your products are to short for their applications typically.
Example 1:
Silent Pro Gold 1200w (flagship product)  matched with a Cosmos Case (flagship product), 4-8pin motherboard power is not even half the length needed to reach the standard placement of that socket on any style motherboard.
Example 2:
JetFlo fan come with 6 inch long connector cable.
Example 3:
SickleFlow Fans... 19 inch cable... better than the JetFlo but still a little short.
I could go on with examples... but I really would like to see these products work with your new cases without tons of extension cables.
Being consistent with your specs would help... be sure to state included cable length on the product specs.
Nothing worse than putting a sweet rig together and finding your one extension cable short!
