B.AMIR
cm 120 jetflow fans compatibilty and and installation on aio watercoolers
B.AMIR    0
hi,
i was wondering if the cm 120 jetflow fans can be fixed onto a corsair h100i gtx or any hydro series aio coolers without any mods?
Sunday Morning    178
Hi
Here is Jetflo specs : 120 x 120 x 25 mm / 4.7 x 4.7 x 1 inch
meanwhile as you mention is : Fan dimensions: 120mm x 120mm x 25mm
i think is no isssue .. the jetflo can fit into the radiator and no need to modify ...
but i like recommend to you using this .. for more perfomence : http://www.coolermaster.com/cooling/case-fan/silencio-fp-120-pwm/
1_597256c88f7608d83beb6e9cc09688a2_14237
Create an account
Register a new account
Sign in
Sign In Now
