Andrew Barton
Cooler Master RC-1200-KKN1 - Cosmos II Ultra Side Fans
Hi Guys,
I recently bought a Cooler Master RC-1200-KKN1 - Cosmos II Ultra, and as I have seen in videos you can take the two fans from the bottom bay that cool the second lot of HDD's and mount the fans on the side to cool the GPU instead.
Problem is there doesn't seem to be any threads in the fan cases to screw them, It actually looks like there should be rubber plugs but I haven't got any in the box.
Has anyone got any experience with this???
2nd question - Would It be ok to fix these fans with sticky fixers?? Where I work they have square pads of double sided sticky pads and they are quite strong. Would this work to mount them?
kind regards
Karri
Create an account
Register a new account
Sign in
Sign In Now
