justice 0 Posted January 23, 2005 i have p5gd1 asus X800XT PE 1024 ram ddr 4x sata 200 GB 3 x IDE 200 GB 2 x ide 80 GB 1 x ide 160 GB i have cross flow and 3 x [3 to 4 modules] meaning all the original coolers [ 120 mm back 80 mm top 3x 12000 front and the cross flow fan ] main power suply : LC Power 550 W 2the Power suply : ATX 250 GT [ P4] = also 250 W i tryed looking for a manual on instaling it but no luck when i start my pc => all the stuff connected on the 2the power suply wont start Quote Share this post Link to post Share on other sites
XFalloutX 0 Posted January 23, 2005 Did you hook the second power supply to where the first one is and see if it turns on the system? Quote Share this post Link to post Share on other sites
justice 0 Posted January 23, 2005 the power suply comes from another computer thad worked Quote Share this post Link to post Share on other sites
Wacft 0 Posted January 23, 2005 while we are on the subject of dual psu's can someone explain how this works? i thought for psu's to work there had to be a load on the atx power cable. Quote Share this post Link to post Share on other sites
justice 0 Posted January 23, 2005 Hold on io try to boot with the other powersuply Quote Share this post Link to post Share on other sites
Guest Mindless Moron Posted January 23, 2005 while we are on the subject of dual psu's can someone explain how this works? i thought for psu's to work there had to be a load on the atx power cable. u use a dongle which has an earth wire and a wire for motherboard detection and hey presto. Quote Share this post Link to post Share on other sites
simplyadvanced 0 Posted January 27, 2005 while we are on the subject of dual psu's can someone explain how this works? i thought for psu's to work there had to be a load on the atx power cable. u use a dongle which has an earth wire and a wire for motherboard detection and hey presto. wire for mobo detection = green wire next to the clip Quote Share this post Link to post Share on other sites
Guest Mindless Moron Posted January 27, 2005 dont forget the earth wire next to it Quote Share this post Link to post Share on other sites
