MOB
MasterCase Pro 5/6 radiator mount
MOB    0
Hello,
i have a 360 radiator and the problem is i can't find any cool case that costs under 200€.
Obsidian 900D sound cool and costs 300€.. i don't want to go over 200€.
Will be there any Big Tower MasterCase or a radiator mount for the MasterCase 5 ?
I had a idea how to build it into the "doors".
ScienceBoy    2
Hello,
MasterCase 5 is Mid Tower
I think "maybe" Cooler Master will produce the full tower version
Maybe 6/7/8/9? :)
knud    129
360mm radiator will fit on the front side of the case. But you need to remove the ODD and depending on the radiator, you might only be able to secure it with 10 out of 12 screws.
(But CM doesn't officially support it, but it does fit, physically)
