Thomas Pedersen
CM 690 Advanced II USB 3.0
Hey there!
Got a quick question and hope for and answer.
I look at my 690 Advanced II case that there is supposed to be two USB 2.0 ports and two USB 3.0 on the top front panel, is this correct or..?
Googled it and found two different pictures, in the first picture there is with 2 usb 3.0 ports as well, but mine looks like the last picture with only 2 usb 2.0 ports...
And now to the question, what is the difference? Why doesn't i have the 3.0 ports?
CM Patrick    34
Hello Thomas,
This is because Cooler Master came out with a revision that came with USB 3.0.
The original model was only release with USB 2.0.
We do sell the USB 3.0 I/O panel on our CM Store if you would like to upgrade your case
http://www.cmstore-usa.com/cm-690-ii-advanced-usb-3-0-i-o-top-panel-oem-package/
Respectfully,
Patrick
CMUSA Support
Dicky Hui    0
Hello Thomas,
Respectfully,
Patrick
CMUSA Support
Hello,
Where can I buy "CM 690 II Advanced USB 3.0 I/O Top Panel" in Hong Kong? Because my CM 690 II Advanced is good but 3.5mm and USB 2.0 are out of order.
Thanks.
Sunday Morning    179
Hello,
Thanks.
bro why you not just direct call at HQ at taiwan ... correct me .. if iam not mistake HK and Taiwan not far isnt ?
Create an account
Register a new account
Sign in
Sign In Now
