B.AMIR
watercooling and aio cooling in the cm storm trooper
B.AMIR    0
hi,
i was just wondering if you can fit the new h100i gtx by corsair at the top of the cm storm trooper case.
in addition, can it fit the new h110i gtx by corsair also in the top. my worries is only the mobo clearance.
CM Patrick    34
Hello B.AMIR,
The CM Storm Trooper supports 240mm & 280mm radiators at the top so you should not have any trouble with the Corsair liquid coolers.
Respectfully,
Patrick
CMUSA Support
Sunday Morning    178
Hi BAmir,
You casn check this : http://www.overclock3d.net/reviews/cases_cooling/cooler_master_nepton_280l_review/4
and this is as you mention :
Technical specifications
  • Radiator dimensions: 276mm x 125mm x 30mm
  • Fan dimensions: 120mm x 120mm x 25mm
  • Fan speed: 2435 +/- 10% RPM
and this Nepton 280L
Waterblock Dimensions 75 x 69.8 x 49.1 mm ( 3 x 2.7 x 1.9 inch ) Radiator Dimensions 311 x 139 x 30 mm ( 12.2 x 5.5 x 1.2 inch )
Fan Dimension 140 x 140 x 25 mm ( 5.9 x 5.9 x 1 inch ) *support 120mm fan x 2
Hope this can help you ...
Create an account
Register a new account
Sign in
Sign In Now
