Tsu Yuan Nieh
GPU fan failure.
Hi, I am a newbie here so I apologise first if there is terms I used wrong or not giving you enough information to answer my question.
I have a problem with my Dell computer, it came with a Nvidia GT705 graphic card; yesterday it started to make a very loud noise and I cleaned it but could not stop it from making the noise. So I removed it from graphic card and looking for a new replacement.
It is surprisingly hard to find one on the market. I think he part number is CM 14 11. It came with the computer so I don't really know the specification of the fan. It looks like about 3 cm in diameter.
Anyway, I really appreciate any help for finding the replace.
CM Patrick    34
Hello Tsu,
I apologize for the trouble with your computer. You would need to contact either Dell or Nvidia for the replacement part since this is an OEM product.
Respectfully,
Patrick
CMUSA Support
Create an account
Register a new account
Sign in
Sign In Now
