The FinalBoss
Which water coolers work on the n400
Hello! I'm looking for a water cooler will work for the n400. The n400 only supports only "select" water coolers (at least that's what I heard) Which ones though? Is it all of them from the cooler master, or just some like only the seidons. Does anybody know? (sorry if this was meant in the cooling selection)
Sunday Morning    177
Hi
Refer our website the N400 is support radiator 240m on the top and the rear side is 120XL
Rear Side Seidon 120XL :
Radiator Dimensions 150 x 120 x 38 mm (5.90 x 4.72 x 1.50 inch)
Fan Dimension 120 x 120 x 25 mm (4.7 x 4.7 x 1 in)
Rear Side Nepton 120XL :
Radiator Dimensions 150 x 119 x 38 mm (5.9 x 4.7 x 1.5 in)
Fan Dimensions 120 x 120 x 25 mm (4.9 x 4.9 x 1 inch)
For the 240m Nepton and Seidon .. you can check the detail at our website
http://www.coolermaster.com/cooling/cpu-liquid-cooler/nepton-240m/
http://www.coolermaster.com/cooling/cpu-liquid-cooler/seidon-240m/
Hope this can help you
Hi
In the manual it doesn't show you how to mount. A radiator on the top? Do I do it on the side?
Sunday Morning    177
Bro
which one you wanna get 120xl or 240m ?
you can check at manual or you can check at youtube : http://www.youtube.com/watch?v=CL_HkQF0dZE , http://www.youtube.com/watch?v=FG2SgRLik18
sorry i cant watch the clip .. my office blocked the youtube website
you can check any detail from youtube regarding the installation
