Trustdesa
Elite 130 with side window?
Trustdesa    0
Hi All,
I truly love my Cooler Master Elite 130, the best compromise between a full fledged PC and a console, I had a 120 which I did not keep longer as the 130 is better under all point of view, design (outside and even more inside).
I was wondering if you are planning to release a refreshed version possibly with a nice windows on the side of the graphic card at all?
I personally run a GTX 970 Nvidia Reference Cooler, Noctua low profile CPU fan and Noctua 80mm front fan, dead quiet at any load despite the size!
James Mason    0
Well, you can see through the grated side panel somewhat.
The problem is a window would put a huge damper on the cooling factor of the GPU by taking away it's access to fresh air.
