Alex Hutch
Haf 932/922 hard drive bracket help!
Alex Hutch    0
Hi,
I have the Haf 932 and 922 cases and they are the best PC cases I have every owned.
The only problem I have with them is the hard drive brackets that come with the case.  The pins with the white rubber band around them can sometimes take ages to install and is becoming a problem swapping out drives.
Does anyone here know of an alternative hard drive bracket that will work with these cases?  A link to the product would be great help too.
Thank you in advance.
tamagotcha that for both the 922- & 932er series: http://www.cmstore-usa.com/haf-series-hard-drive-tray/ - link there to hot swap bays as well.
..not only here might prove a surprising-a-ling at Google's bring up results. Now let's look for a breeze of change what can sort the conundrum at the Admins booth, ta da. WhereIsEySpacebarWhenYouNeedOne...
PS: fingernails grow strong with minerals and trace elementals
