RIAD
CM Sentinel Z3RO-G not working
RIAD    1
hi everyone how to solve my problem Sentinel Z3RO-G that does not work after update firmware
  • Upvote 1
Pclinde    197
Can you please share some more details?
  • OS?
  • Please try a BIOS update
  • Try various USB ports (both 3.0 and 2.0)
Cheers,
Pim
RIAD    1
os win 7 Ultimate 64bit
firmware 1.5
usb 2.0
connecte & déconnecte how to solve this problème
Pclinde    197
firmware 1.5
usb 2.0
Hi,
Try to update the firmware again or on another PC.
Make sure you're using the latest software: http://gaming.coolermaster.com/en/products/mice/sentinelz3rog/
Cheers, Pim
Pclinde    197
hi the problem is repeated every time :(  what i have to do :unsure: ?
Does it still light up? Is it listed in device manager?
RIAD    1
Hi, THX for reply,  yes it's listed in device manager but when i paly CS:GO connecte & deconnecte rapidly , i reUpdate it in an other PC reInstall the driver change usb port every day same problem what the solution plz help me .
CM Bram    37
Hi RAID,
Is this only happening in CS:GO? Did you also try this on a different PC? What firmware have you downloaded (on our gaming website it only lists a Software AP as download)
Regards,
Bram
