tva
2 Questions: Hyper 48 Installation and Effectiveness
Guest Mindless Moron
unfortunatly the instructions for such items are useless i suggest you jsut try to figure it out sorry, but the clips shall hold it just be careful whenm ur pc is in the car, flat pack it.
okay Sry for my first post here
it just when i call other prodcuts i dont Always ment that they do it Better
i use CM products for almost 12 years now
got one TT but Replaced it with CM agan
i always liked CM more there products always looks great
and also preform Better then most other produccts
TT is more overkill looks
CM High Performance in an Neat way (like the Hyper 48 and 6
they look awesome and work Insanly good (thanks to the copper and Heatpipe and some Darm good Engineers)
i dont know who edited my Post but it cool
BTw for the other dutch huy
Make a Fem PPhotos of the Bracket and the HSF fan on it
you Mentiont that i will not fiit exaclty goo right
did you look for any movement of the sink mabe something is blocking its way
tip for the Photos
make a Top view and a side view of the socket
then do it agan but then with your Hyper 48 on it
but do it close dont whant to see th entire Heatsink just the bottom of
it
but its a gigabyte he maybe the DPS thingy is blocking it
Create an account
Register a new account
Sign in
Sign In Now
