defrule
Thermal compound
defrule    0
If my heatsink comes with a layer of thermal compound, is it enough or should I buy and add some more to it? After all, it only is a thin layer you get.
Hybrid-Mods    0
If you are going for the best, I will advise you to clean that layer of thermalgrease off, and go buy some Arctic Silver 5 or OCZ Ultra 5+.
Mr. Miyagi    2
Take Hybrid's advice. When you clean it, you should use a 100% non-static cloth and higher than 90% alcohol.
VoongKoong    0
You can get the alcohol at a local Rite-Aid and it's called isopropyl rubbing alcohol. This is used to clean out the remaining thermal compound left in the small microscopic gaps on the core's surface.
Johan    0
Yes, see above... Your local 7-eleven will only offer you Ethanol that is 55% and ment for internal cleaning of belly and intestine.
Not good for heatsink.
